MMOexp ARC Raiders: Quest Rewards and What Comes Next
That said, be cautious. Extraction points in swamp areas are often prime ambush locations, and the Central Swamp Lift is no exception. Before initiating extraction, take a moment to scan your surroundings, check sightlines, and listen for enemy movement. Keeping your weapon ready could mean the difference between a successful extraction and losing your newly acquired key.
If everything goes smoothly, extract and return to Speranza to turn in the quest.
Upon completing A Toxic Trail and reporting back, you'll unlock the next quest in the storyline: The Stench of Corruption. This follow-up continues the investigation into the poisoned water supply and is required if you want to earn the Warden outfit, one of the standout cosmetic rewards tied to this questline.
While A Toxic Trail is relatively short, it plays an important role in advancing the narrative and setting up future objectives. It also rewards attentive exploration, encouraging players to revisit earlier locations and re-examine clues with fresh context.
Final Tips for Completing A Toxic Trail
Extraction isn't required, but highly recommended if you want to keep the Spaceport Warehouse Key.
You don't need to interact with the barrel-just standing in the contaminated water progresses the quest.
The truck is nearby, so avoid unnecessary combat or risky detours.
Always check the Central Swamp Lift for campers before extracting ARCR Items.
A Toxic Trail may not be the longest quest in Arc Raiders, but it delivers meaningful story progression and a useful reward if you play it smart. Stay alert, follow the clues, and you'll be one step closer to uncovering the truth behind the water contamination.
If you want to climb the Arc Raiders leaderboard or simply secure strong weekly rewards, mastering the trial system is essential. Trials are among the most competitive activities in the game-high pressure, heavily optimized, and demanding precise routing and teamwork. This guide breaks down the core rules, the best maps, spawn systems, and high-level strategies used by top players to consistently secure elite scores.
Why Trials Matter
Trials are rotating, time-limited challenges that award points based on performance. These points determine your weekly bracket placement and reward you with cosmetics, blueprints, and progression boosters. While reaching the upper leaderboard brackets is tough, understanding the mechanics dramatically improves efficiency-even for casual players. Knowing which trials are worth running, which ARCR Items to bring, and how enemy timers work can completely change your weekly results.
The Three Golden Rules of Trial Success
1. Prioritize 2× Multiplier Trials
Certain trial types-such as Night Raids, Electromagnetic Storm, and Hidden Bunker-offer powerful 2× point multipliers. These should always be your first choice, as they significantly outperform daily modifiers like Prospecting Probes or Lush Blooms. Even when extra mobs appear in those daily trials, you rarely have time to farm them efficiently. Multipliers are king.
2. Go All-In Every Run
High-tier trials require heavy investment. Top scores consistently use:
Wolf packs
High-tier guns
Lure and blaze grenades
Mines and barricades
Multiple stims
Half-measures rarely succeed-commit fully or try again later.
3. Learn Enemy Spawn Patterns
Arc Raiders' enemy spawns follow predictable, fixed rules. For example, Leapers in Damn Battlegrounds always rotate between four set spawn points. Killing one starts a respawn timer, and optimal runs manipulate this timing to secure multiple waves in a single raid.
Every player needs a lot of ARC Raiders BluePrints, I suggest you go to a third-party website like MMOexp.com to buy, safe and comfortable transactions, and years of experience to ensure the security of your account.
SSD WD_Black SanDisk 2To à
158,90 €
24,21 €
Booste ta Freebox Delta
Mini PC NiPoGi Hyper H1
Le Cloud Gaming gratuit !
La manette Amazon Luna
Amazon Fire TV Stick HD
